4 minutes ago, gr5 said:It is? I thought the scan line thing was wrong and the order placed idea was the correct one.
3d printers (or at least my ender 5) do not see the objects in the same way we do. they have to think in grids alongside your preferable settings (temp, speed, nozzle travel inside only etc.) but that's per each flat shape they have to do in the layer. and theyll work from the nozzle home to the opposite corner. so to manipulate its algorithm you need to understand how its going to calc the next way point( x,y or y,x ). then adjust. I'm satisfied with how mine turned out, just kept moving the one i wanted to go last further out of order and the one "next in line". just keep clicking away till it works in the order you want.
12
9
6
5
Popular Days
Mar 8
10
Mar 7
8
Mar 9
6
May 25
5
gr5 12 posts
rachael7 9 posts
Slashee_the_Cow 6 posts
Cuq 5 posts
Popular Days
Mar 8 2024
Mar 7 2024
Mar 9 2024
May 25 2023
Popular Posts
jeroent
Hi guys, I ran into the same issue; wanting to print one-at-a-time and finish the parts from the front of the buildplate to the back. At first i also noticed that cura 5.5.0
vela0050
There is a way to print in the order you want and its pretty simple in cura. All you have to do place the items closest to the "scan line" and it will print in that order. Let me explain:
jackharvest
8 Years in, and still no proper way to change the object list order (AKA, the print order of objects in One at a Time mode). I print clips. An EFF ton of clips. I have to print them one at
Posted Images
gr5 2,189
I think we do have it. Read above. It's the order you load the STL files. At least it used to be. I'm pretty sure it still is.
