cloakfiend 992
Acetone smoothing is the only way to go with PLA in my opinion, and I do TONS of it. But it all depends if acetone plays with the particular brand of PLA you are using (remember that PURE PLA is unaffected by acetone!). Also remember that ANY lumps bumps or scratches or anything will show up on your cast so take the time and make it perfect (means loads of delicate precise sanding regardless of any acetone dipping and post work!) Stuff for casting has to be perfect or else all the results will be lame. I just paint my stuff in DIY metal paints and save a lot of time messing about with resins and other chemicals making casts unless you are after actually functional parts. My room looks like a terrorists diy bomb factory with bottles of chemicals spread out all over. lol.
That XTC-3D has always looked crap in my opinion and a total waste of time and money creating wobbly and imperfectly smooth surfaces which still blatantly had the lines in them. You are better off just using filler, or if your model is complicated then invest in some PLA that plays well with acetone and use that to print with exclusively.
But don't expect good results if you print in low resolutions. Smoothing is not magic, the less detail to play with the less you will get at the end. 0.06 is fine and 0.1 is fine for vertical stuff, depending on the brand of PLA once again. To be safe i would recommend UM dark blue PLA as from experience i found this one to be the best. then just a light quick sand to remove any ringin or slight imperfections, chuck your prints into the acetone for 25 or so seconds, and job done!
Good luck.
EDIT: (UM PLA DOES NOT SMOOTH ANYMORE, THEY HAVE CHANGED THE MANUFACTURING PROCESS) Use colorfabb instead.
Edited by Guest-
1
Labern 772
I haven't used it for that purpose but I have used it. its ok but not as good as i thought it would be.
I would suggest acetone smoothing as it wont add any impurities into the cast
