DidierKlein 730
cold or warm it doesn't matter. It must be just humid to apply the glue on the whole plate (it must stay dry)
I send you my video.V_20150827_135856[1].mp4
Is it ABS or PLA?
ABS
I follow your suggestion but I have a Same result.
have you another suggestion for me?
Ok ABS is tricky.
You can start by adding a brim in Cura (option under platform adhesion).
With ABS you can also disable the fans, i'm not an expert in ABS printing (i hate ABS )
You could also try to print the first layer a little bit slower and potentially put the bed a liiiiiittle bit higher?
Haaa... I try and try with another settings but I have a same result. Oh my God haa...
Maybe I want to try with PLA Material.
PLA usually is easier to print with, and may help you understand the mechanics and material better. When you are more experienced you could try ABS again.
What should I do?
There should be to setting in the Printer?
I was try to setting Speed till 80%, The print quality is a high quality. and then temperature at the plate is 95 C.
You have other settings? can you share with me?
Ok, I will to try printing with PLA.
Thank You for your Information.
Select PLA settings in your Ultimaker 2, before you start printing with PLA
Haa...
I Was to try with My Ultimaker Setting but the result is same.
and now I try printing with PLA material and Binggo is so Good result Haa.....
But I'm Curious about ABS, why is very difficult to the setting??
Anybody to share the experience with ABS to me? haaa....
This is the result when I used PLA material.
Thank you very much for Mr. SandervG and Mr. DidierKlein
Problem with ABS is that it will retract a lot, that's why it's difficult to print. Personnaly i don't print ABS because of this and also because it smells bad (only print in a well ventilated room).
I prefer to use XT filaments from Colorfabb for prints that require strength
XT Filaments From Collorfabb is a type of material??
and Ultimaker to Provide the material??
XT Filaments From Collorfabb is harder than PLA?
Yes XT is a type of material. XT, PET and CPE are all very similar.
Ultimaker supply CPE
If you try to bend PLA it will break but you can bend XT a lot more before it will break.
It also has a higher Glass transition temp which means that you prints can withstand higher temps. if you leave it in a hot car it wont warp.
Edited by GuestABS is more difficult to print than PLA. They are almost opposite materials where PLA likes to be cold ABS likes to be warm. My advise use PLA to start with, as you noticed...
Use colorfabb XT if you need more temperature resistant parts. Only after that think about ABS.
I print ABS with 260 degrees (this is hot it will deform your teflon part in half a roll of ABS, my observation and that is why I use a E3D full metal hotend) and my bed at 110 and a good glue stick or ABS slurry. And always use a brim for ABS. Also note ABS shrinks so it can wrap and pull off the bed. So when you have been able to keep ABS stick to the bed getting it off can cause issues again. I once chipped my glass pretty badly when the ABS cooled off.
Keeping ABS warm in a covered machine also helps fighting wrapping, but you have to be careful with your stepper motors to run it covered.
So all in all don't start with ABS but start with PLA to build some experience, and then you can use ABS.
ABS is a nice material if you need to post process it. Although with PLA you can also do a lot just remember to keep it cold (I sand it or file it).
PLA is much easier but with practice you can get perfect ABS prints every time.
Thank you for your information,
XT is a better than PLA I think, so what about XT be compare with ABS?
ABS is familiar with human cos ABS is environment friendly materials.
so what about XT?
Thank You For your information Mr. Zoev89
Yes I think so.
I try with ABS but failed result, and then I try with PLA and so easier.
But I'm a curious with ABS. heee....
XT is not as easy to print as PLA.
It's more prone to Stringing and layer adhesions issues. Can have some warping but not to bad
It similar properties as ABS but no smell, it's also meant to be food safe and recyclable.
there are many debates about what is hazardous to health and environmentally friendly with all filaments.
DidierKlein 730
Hi Fredhi,
Welcome to the forum
First thing to check is the level of the build plate.
Yout first layer must be squished on the platform. If the first layer doesn't stick well and the layers are "rounded" then your buildplate is to low.
If the first layer is almost transparent then it's to high.
What printer do you have? Assuming you have an Ultimaker 2 you can fine tune the level of the plate during the print of the first layer (best when printing the brim or the skirt).
You can also apply the some glue that was sent with the printer. Put some on the glass and apply it smoothly on the glass with a slightly wet cloth.
Maybe some pictures could help, and tell us what material and settings you are using!
I hope you understand everything i write
Yohanes 3
Thank You Mr Didier Klein For Your Attention.
My Printer Is Ultimaker 2.
I've done all the procedures from Ultimaker but the result remains the same.
and now I fell so confused haaa....
But your explain to me so after I apply the some glue and then I also apply smoothly on the glass with a slightly wet cloth, and I want to try your suggestion. Mr Didier Klein, I use
Cloth with warm water or cold?
Thank You Very Much
You've taken the time to help me
