angle in 3D printing without support?
neone
Posted · angle in 3D printing without support?
If you are on a stock UM2, this will depend on which way the angle is facing as one side cools better then the other. Also layer height can have an effect on the outcome. Typically 45deg angles turn out pretty good.
but you can get away will quite a bit more.
That's great
There is also an angle test Here that can help find the maximum angle you can print at. If you print it at different angles like your test will help show the best way to orientate your designs. But you need to do this one at a time as printing more then one adds heaps more cooling time.
You also now need to focus on getting rid of that Stringing.
Posted (edited) · angle in 3D printing without support?
Thanks @Labern for the tip,
I put the angle test up to the test and it came out pretty neat! At 70 degrees the buttom side of the piece is not that great, but it's good to know.
(positioning in the center of the plate/easy settings/medium quality)
45 degrees is the general rule for good looking surfaces. If you don't care how it looks you can go almost horizontal - certainly up to 80 degrees from vertical no problem. But it will be ugly.
yeah, that angle test showed a pretty nasty surface underneath on 70 degrees. 45 and even 60 was still pretty decent.
Meanwhile i tried testing vertical printing some more without supports, this time with a thicker model (2mm) ...it came out almost perfectly without a scratch!
