Do a google image search on the feeder to see how the tension is controlled so you can see what is inside - once you do all is obvious.
But that's probably not your problem. The feeder is purposely given less current so it only has about 10 pounds or 5kg of force. Any more and the filament gets ground up. So the first thing to check is what temperature, speed, layer height are you printing at.
Here are my recommended top speeds for .2mm layers (twice as fast for .1mm layers):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion. Different colors print best at quite different temperatures and due to imperfect temp sensors, some printers print 10C cool so use these values as an initial starting guideline and if you are still underextruding try raising the temp. But don't go over 240C with PLA.
Also check your temp sensor because they can easily be off by 10 to 30C:
Hi gr5
I did forget to mention that the feeder makes a moderately loud beeping noise when I'm in the 'move material' setting, not sure if that has much to do with anything. As for the print settings, very helpful will definitely use them as I've been printing too cold. I've been doing 40mm per second at 210C. I generally use 0.1 for layer height.
gr5 2,334
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
