bioFila PlaTec
foehnsturm
Posted (edited) · bioFila PlaTec
Some time ago, I started a topic about bioFila linen filament and it's impressive print quality. Actually my most immaculate prints ever were with this filament.
Now there's a new one, PlaTec, which withstands temperatures of up to 110-120 °C!
The first print looks promising. It actually prints at least as easy as regular PLA and way more easy than PLA HT for instance. The three robots have been printed with the gcode which comes with the UM2. Only temperature was adjusted, PlaTec only needs some 190 °C. Of course only one of them has been boiled in hot water.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
OK, despite the 'Bio' term I would expect this material to contain a lot of additives; such a high glass temperature has nothing to do with ordinary PLA. Interestingly, there is no safety data sheet yet for this material. I would make sure the printing room is well ventilated and I wouldn't stay close to the printer while this material is printed (greetings from ABS...).
change language
    Posted · bioFila PlaTec
    @ultiarjan
    No treatment, just printing, less warping, good layer bonding
    @Dim3nsioneer
    Nope, I assume despite it's called "PLA.." it's closer to the other BioFila filaments which are based on some lignin stuff.
    @DidierKlein,
    same opinion here ;) People always look for bright colors but maybe not enough for material quality and tactile feeling.
    Ok, I'll need to try this... just ordered a spool... 59 euro including shipping ....
    If it prints easier as ABS and really withstands 115c I don't care about the available colors.
    Really curious about your opinion.
    190°C vs +250°C would be a be huge advantage regarding PTFE lifetime.
    @Dim3nsioneer
    http://two-bears.eu//index.php?s=82
    No related to them in any way but loving "outsiders" ;)
    @Dim3nsioneer
    Yes, that's the page where the PLAtec sds should be.
    Well I'm currently doing ABS on the E3Dv6, but if this stuff really works I'll probably build it back to the UM head, which I find easier in daily use, easier on stuff like atomics....
    Does the plaTec stick to bare glass? did you use glue?
    @Dim3nsioneer
    True, so let's try to get a statement from the originators here. Should be possible without disclosing essential company secrets. After reading all of the few information available, they actually call it a "PLA blend" and claim it to be food safe.
    @Ultiarjan
    last print was bare glass, no glue, 54°C bed
    A double walled cup. Still have trouble to get the inner shell watertight, the outer one always is.
    Just did my first test, had to be creative to start, the spools have a tiny hole.
    Printing was very easy, used my PLA test, starting at 210, in 5 degree steps to 190 (0.4 nozzle)
    As this material has a high temperature resistance (softening temp 120 is what they claim) I boiled it.
    You see the part deforms at the thin areas, but the thicker areas stay ok.
    Unfortunately I found huge de-lamination after the boiling, maybe it was there already but did only try after the boiling. It was no only at the temperature change height, but basically everywhere.
    I feel the de-lamination is a bit of a disappointment, but its just the first test so to early to conclude anything, just will not throw out the ABS yet  :)
    some extra notes:
    used laberns fan mount, 100%, maybe next try a bit less fan.
    first indication of the test, on MY printer it seems to need a bit more than 190 print temp (look at the bridging)
    Interesting!
    I'll print some thinner structures the next days.
    Excuse my ignorance; was the boiling to test the temp. resistance or was it part of the production process. There are no production comments on the website although the Silk filament has extruder and bed temps + print speed - does it come with instructions for those aspects or did you read this somewhere else?
    just testing temp resistance.
    I'm sure I read the print temp of 190 celcius somewhere.... but can't find it anymore on the site. When I'll get some time I'll do some testing on print temp vs layer adhesion. There's no print info on my spool.
    The 115 c melting temp can be found in the material data sheet available on there site.
    Thanks guys, it sounds a really interesting filament so I am thinking I will dive in a give it a try.
    Recently I made some molds for silicone casting. To speed up setting they have been heated to 85 °C with no problems.
    I also printed a thin walled thing, a cookie cutter and can confirm @ultiarjan's observations. It became considerable softer during boiling. However, no de-lamination and everything ok when cold again.
    Just tried PLAtec, amazing filament! Especially overhangs become super nice but also walls and surfaces. With PLA I have never come anywhere close to that on a standard UM2 with some additional fans blowing in the front. The look reminds a bit of those milky SLA prints :-P Only thing I don't get right is bed adhesion. I thought it whould adhere quite well to a clean glass bed. Tried 55 and 65°C but even a 3Dbenchy or 20x20mm block warp considerably. PLA and biofila silk stick nicely. @foehnsturm, @ultiarjan, Did you have any problems with that?
    I can confirm the warping / bed adhesion issue. Without brim edges are likely to curl up. It's also a little more waxy than PLA, not as much as PLA HT for instance but you have to be careful with a cutter.
    What a pity! Apart from that warping this is an absolute nobrainer. Thank you for confirmation.
    Anyone tried Green-Tec from Extrudr ?
    I bough a roll from them since seems to have the same 110-120C and it's a little bit cheaper than bioFila since they sell 600grms for 49€, and Extrudr it's a full kilo for 56€ and they have 4 colors to choose.
    I'll post some test with it as soon it gets here since I want this to print a fancap and some cups for my wife since they have the food contact approval.
