@cloakfiend, thanks for replying, I will try the 0 % infill, but with a higher top thickness, otherwise I'm afraid it won't close nicely.
I'll also try to print more than two at once. And even slower and lower temperature.
Here are the pictures from the finished print of today. I still notice blobbing, and also strange shapes in the wall:
cloakfiend 992
retractions shouldnt be an issue, smaller stuff is harder due to heat being more of the problem, also id have either 100 % or zero infill as weird denominations on tiny stuff can damage the surface due to the walls still being affected by movement of the nozzle.
and yes don't print loads of different shaped stuff at once unless you dont mind seeing layer lines due to mismatched cooling times per layer.
Colourfabb red is fine, i swear by traffic red i highly recommend printing like 4 at a time, 2 may not give enough time to cool.
Not sure if my settings will work given that each machine may read temps differently but i use...
temp 185 layer height .06 speed 30. all walls 1.2. and fans on full from the very start. tats it everything else default on cura 15.04.2.
Edited by GuestLink to post
