cloakfiend 996
I used to get this from time to time and sewing oil solved it for me, just lube up all the horizontal rods and see if that helps. You probably have dry rods and loose pullies. lube helps, but it means something is rubbing.
SandervG 1,522
Hi and welcome to the forum.
Were there any error messages in your UltiController when you returned to your Ultimaker?
I would suggest to check all the pulleys in your Ultimaker, make sure the set screws are all nice and tight. Remember, there are 12 of them, don't forget the ones on the X and Y motor.
While you are at it, make sure the short belts are tight.
Alternatively, it could be an error in your end stop, but that should probably trigger an error message.
Good luck!
