Hi, the extrusion upgrade kit will be available in March.
We mentioned Q1, so the stretch is a little bit longer than Jan- Feb.
With it you'll be able to upgrade your Ultimaker 2 (Extended) into an Ultimaker 2 (Extended) +.
So just a little bit more patience is required, thank you!
Wisar 86
Good news that it is going to be available at all so will be interested in the answer as to when ... but wondered if this also pertained to the change in the fans configuration that resulted in "optimized airflow"?
