Tensioning the belts would be my first port of call as such behaviour is attributed to loose belts.
The other port of call is try another slicer program.
The overall dimensions - all parts will have some shrinkage. You will find the printing order (perimiter->infill-> loops etc.) will affect the way the overall dimensions vary quite signficantly. The best way is to use a path plan that give you your desired surface and strength properties (or as close to) then bump the dimensional tolerances on your model to compensate for the final bit of variation.
IRobertI 502
I have no thoughts or solutions for it but I can confirm that I've seen the same behaviour as well (although not quite as severe). When it happens it is always on parts similar in shape to what you show here. I don't have any examples handy as I haven't been printing much the last few months. I always figured it was just my machine, maybe that's not the case then.
