As @Nicolinux said, is not easy.
You will need to fix and modify your file to make it printable as you wish.
Is a tipical problem with architectural models, because the software doesn't make you to draw it to be 3d printed in a 1:100 scale, but to draw it with a 1:1 definition, making imposible to achieve a nice and clean miniature model.
I use to clean up the models with Rhino, because when the model has been cleaned up, I can merge everything as a single solid and test the mesh if it has open faces and repair it.
But it takes time.
Nicolinux 288
That's not that easy to do. It depends on the source file format and the tool you are using. I fought with Blender a while ago trying to do the same but gave up at some point.
