Thanks guys 8)
2
- 3 years later...
I know I a getting an old post up again but I am trying tu fit this modification on my old Ultimaker original with a 32 bit board, custom heated bed and Marlin 2.0... I think some things have changed, I can't find the Prepare menu for example...
Did somebody allready try this in marlin 2.0? (I am very bad at code... but I try to learn and understand)
Thanks a lot!
Top Posters In This Topic
29
20
12
6
Popular Days
Jan 23
11
Feb 2
10
Aug 15
7
Jan 25
7
neotko 29 posts
amedee 20 posts
antiklesys 12 posts
tinkergnome 6 posts
Popular Days
Jan 23 2017
Feb 2 2017
Aug 15 2016
Jan 25 2017
Popular Posts
neotko
V4 Version update 24th August The original idea didn't work, but all the Firmware changes (most of them) do work with this (I think final) version V4 that places the Endstop on the bottom.
Posted Images
amedee 349
Yes indeed, I am an OctoPrint user...
It is a design from @adrien_12 : it is on YouMagine.
Very simple, but effective.
catohagen 41
Updated firmware with https://bultimaker.bulles.eu/experimental and its perfect!
Thank you Amedee
I'm using Neotko's homing at bottom of bed modification.
Also tried the software bed levering, very cool
AND finally I have a nice *beep* instead of that hideous stock beep !!11
I did an PID autotune....and was wondering would it make sense to be able to build
a firmware and you could set the PID values in the online builder ?
Last week i got lots and lots of MAX TEMP errors on bed (UMO HB upgrade kit) and I ended up removing the whole crappy connector and solder the wires for the sensor and power for bed directly on the bed.
But now the room temperature readings are different....if I turn on printer its shows 24° on hotend and 20° on bed....maybe if my soldering have altered the effect on the sensor...also I need to use hotter bed to get stuff to stick...will autotune PID fix this difference or is that another matter (temp difference) ?
Edited by GuestLink to post
neotko 1,417
@Amedee rocks!
