Dim3nsioneer 559
Hmm. Simply making the longholes longer would do the job too, wouldn't it? Made that on my UMO. I'm actually more worried that one day the bed could miss the lever. Adding a spacer there is not possible due to the x-block. Btw. you should be aware that you are at a different height with the UM2+ head compared to a standard UMO+.
I think I now what you mean. You want to drive the z axis further despite the z endswitch being hit. That's too dangerous IMHO. The endswitch should make the axis stop. Anyway the movement would be too unprecise as the hit point would be somewhere else each time.
neotko 1,418
Indeed. The problem on umo+ it's that it physically limits the movement. While rotating the endstop the bed could still move beyond the limit. By changing the endstop to this position the bed would hit the endstop but it's movement won't be block by it, therefore it would be posible to redefine the offset by firmware.
Madrid today weather it's fantastic, only 31C
Edit. Yeah that's the bed shape:
