I have seen this a few times, the OLED displays does have problems with burn-in, and there is not much to do about it except the above solution... (@tinkergnome does create great stuff)
1
Hi folks,
I also have this issue. It did some research on it and it seems that OLEDs are subject to burn-in. ... like old CRTS, and unlink LCDs! :(
Some people, in the context of OLED TVs say that if you turn all the pixels on max and leave it for a long time, you can at least burn all the pixels to the same level and hide the ghosting. (Sounds dangerous to me!) But you cannot actually fix the problem once you have it.
I was quite surprised that no one else has mentioned it until now. (not even me!) :( Thanks flowalistik!
For me it occurred because I will put on 5 or 6 hour prints over night or while at work and then it sits there saying "done" for a 2-3 hours after that because I am still asleep or at work.
In fact, screen blanking was one of the major reasons I switched to Tinker's firmware. (The other being 300C for polycarb).
I would seriously recommend that the stock firmware be changed to have some kind of basic blanking capability because of this. I was really bummed out when I first saw this. It still bugs me every time I see it. That's my $0.02. Also, can we buy replacement OLED displays?
Anyway, I hope this helps. Glad to know I am not the only one!
@krys I checked today and I've been printing for 6666 hours, but the printer has been on for 9000 hours, mainly because I also leave print at night that finish printing at 4-5am, which leaves a time gap until I get off bed.
Yeah, I am in a similar boat. 5000hrs printing, quite a bit more just "on".
ThinkerGnome's firmware both lets me reduce the brightness of the display and has the screen blanking. I appreciate both very much.
Though, it is weird to see the printer printing with the lights and screen off. Seems like it is possessed or something!
It seems to me that you could interrupt the power line to the screen with a SPST switch. Flip it on, the screen gets power. Flip it off, screen is unpowered.
I'd have to research and track down which line is power (which shouldn't be too hard), but it would involve cutting traces, so definitely not for the faint of heart.
Edited by danyetman
tinkergnome 917
Well... or a custom firmware where you can adjust the screen contrast and where you can define a sleep timer that switches off the led lights and/or the screen after a certain amount of time without user interaction...
You're right, it's too late for you, but it's there (since a year or so...)
flowalistik 181
It'a already done! You think about absolutely everything! <3
