Avoid first small filament line
DudeUser
Posted · Avoid first small filament line
Hey,
how can i avoid this first line of filament when the print starts?
It is alwas in my prints and doesent look good. When i print the Ultimaker Robot
the printer makes a small border and then starts the print so there is no small line in
the print. I hope you can understand what i mean.
    I guess you mean that the material that is purged from the nozzle in the front left corner does get pulled with the head and stick to your model, but on the UM robot it has a skirt where that filament stick instead.
    If i get that right, just make sure that you are printing with at least one line of skirt.
    How can i do this? I always print with brim.
    Do you mean "Brim".
    5a33204b07b53_Brimof.thumb.JPG.b92030508f810fb3dccd93343a9a8d87.JPG5a33204b3407d_Brimon.thumb.JPG.e3fe1bfed8e3172196a7486f8ebef25c.JPG
    You can get rid of it by selecting brim or skirt and setting lines and minimum skirt length to 0. But I don't recommend that. Skirt gets things going nicely so you get perfect printing. If you skip the skirt you will get an underextruded part of the bottom of the robot and it won't look as good. Also it might fall over (not stick as well).
    If you have a "blob" connecting to your skirt or print then grab the blob at the begining of the print with your fingers quickly and pull it away from the print before it starts the skirt.
