Well another issue I noticed is despite saving the values, if you power the machine off and on....the materials you added on not there.
I have followed the instructions and something seems to be missing. I had to re-upload the data again.
Can someone from Ultimaker check into this? It's annoying to have to keep importing it from SD card. If I power the printer off, then on...my additions are not there.
Well perhaps the online documentation should be updated to reflect it doesn't work as designed. And save others some frustration
https://ultimaker.com/en/resources/20982-custom-materials-ultimaker2-plus
Any update on a fix for this?
It's annoying to keep Importing it over each time I power on the printer. Thanks!
Let me see what I can find about this..Any update on a fix for this?
I really appreciate that. I know I could edit the existing ones but the option of adding is so convenient
Hi @sandervg
Just checking up on the Material.Txt having to be uploaded every time, since it does not store these on the Ultimaker 2+ (Once you power down, it's gone...you have to manually upload it all over again)
Any fix in sight?
I think @Nallath would do a better job in answering this?
Those material profiles are for firmware. I have little to no knowledge about it (as I mentioned in the first post). @Daid should know about this.
Hot potato time!
Yeah nothing to do with Cura on this one. @nallath is off the hook!
It has something to do with firmware, since that uploaded data is being lost once the machine is powered off.
If you have many SD cards, it can be a hassle remembering which one has the materials.txt file on it!
Edited by GuestI've updated recently to the 2.3 Version. And now the materials are not saved any more during a power cycle.
In the 2.1 Version it worked fine.
@tinkergnome - any insights? I haven't used the materials.txt feature. After you load them is there some save command somewhere you have to do to write to eeprom? Or could it be that some materials.txt files have something that won't write to the eeprom? Or they have too much information? (I know not that much memory is reserved for this).
@m42e and @LePaul please post the entire contents of your materials.txt file in case there is a character in there or length of string that is causing the problem (maybe materials have to be less than 10 characters long for example).
And note that when you upgrade your firmware - some firmware versions use different locations of the eeprom differently and sometimes your settings get clobbered until you resave or do a factory reset and then re-enter settings.
@gr5. Thanks for inquiring! I'll post the contents of that file when I'm home this evening! I'd love to know why it won't save
AFAIK it's just a firmware bug - and exists since Ultimaker added the retraction settings per material. But i may be wrong...
Here is a reported issue: https://github.com/Ultimaker/Ultimaker2Marlin/issues/113
...and:
@ghostkeeper added the "bug" label on 5 Sep
I assume, he has the hot potato at the moment...
(or at least - some insides?)
Edit: here is another one: https://github.com/Ultimaker/Ultimaker2Marlin/issues/121
It turns out that @daid now owns the hot potato - as always...
If he says "it's a bug" - then it's a bug
Hi @gr5 and the gang
As the others pointed out...I don't think it's me.
Here's my file I have to import everytime I power up to use Colorfabb nGen (I find these settings work great, reducing the 'hairy' prints significantly)
I can't figure out a way to attach the txt file asides cutting/pasting it in here
[material] name=PLA temperature=210 temperature_0.40=210 retraction_length_0.40=6.50 retraction_speed_0.40=25.00 temperature_0.25=195 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=230 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=240 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=240 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=60 fan_speed=100 flow=100 diameter=2.85 [material] name=ABS temperature=260 temperature_0.40=250 retraction_length_0.40=6.50 retraction_speed_0.40=25.00 temperature_0.25=245 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=260 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=260 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=260 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=80 fan_speed=100 flow=107 diameter=2.85 [material] name=CPE temperature=250 temperature_0.40=250 retraction_length_0.40=6.50 retraction_speed_0.40=25.00 temperature_0.25=245 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=260 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=260 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=260 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=70 fan_speed=100 flow=100 diameter=2.85 [material] name=PC temperature=260 temperature_0.40=260 retraction_length_0.40=6.50 retraction_speed_0.40=25.00 temperature_0.25=260 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=260 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=260 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=260 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=110 fan_speed=100 flow=100 diameter=2.85 [material] name=Nylon temperature=250 temperature_0.40=250 retraction_length_0.40=6.50 retraction_speed_0.40=25.00 temperature_0.25=240 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=255 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=260 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=260 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=60 fan_speed=100 flow=100 diameter=2.85 [material] name=CPE+ temperature=260 temperature_0.40=260 retraction_length_0.40=6.50 retraction_speed_0.40=25.00 temperature_0.25=260 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=260 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=260 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=260 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=110 fan_speed=100 flow=100 diameter=2.85 [material] name=TPU 95A temperature=235 temperature_0.40=235 retraction_length_0.40=10.00 retraction_speed_0.40=25.00 temperature_0.25=235 retraction_length_0.25=10.00 retraction_speed_0.25=25.00 temperature_0.60=235 retraction_length_0.60=10.00 retraction_speed_0.60=25.00 temperature_0.80=235 retraction_length_0.80=10.00 retraction_speed_0.80=25.00 temperature_1.00=235 retraction_length_1.00=10.00 retraction_speed_1.00=25.00 bed_temperature=70 fan_speed=100 flow=100 diameter=2.85 [material] name=nGen temperature=230 temperature_0.40=230 retraction_length_0.40=4.5 retraction_speed_0.40=45.00 temperature_0.25=195 retraction_length_0.25=6.50 retraction_speed_0.25=25.00 temperature_0.60=230 retraction_length_0.60=6.50 retraction_speed_0.60=25.00 temperature_0.80=240 retraction_length_0.80=6.50 retraction_speed_0.80=25.00 temperature_1.00=240 retraction_length_1.00=6.50 retraction_speed_1.00=25.00 bed_temperature=80 fan_speed=50 flow=100 diameter=2.85Edited by Guest
Here's my file: http://filebin.ca/37Os6rMqEMMf/MATERIAL.TXT
@LePaul I think you should downgrade your marlin for now. I only upgrade marlin maybe once per year no matter how many versions come out in between. But that's mostly laziness (even though it only takes 5 minutes).
@gr5 why would i want to rollback? I did the latest firmware upgrade for the Um2 to UM2+ extruder upgrade. The materials file has been identified as a bug by Ultimaker staff. I'm fine manually uploading the file on each power on for now. It will be really nice when it works as advertised
Oh right. Plus upgrade. Definitely have to upgrade firmware for that to work!
I only want to say I am suffering the same problems with MATERIAL.TXT as lepaul and m42e
I have posted my case in Very long retraction problem with ApolloX (Formfutura) and What are the various parameters in the MATERIAL.TXT file? threads, as I didn't discovered this topic before.
As far as I can see, there are two bugs:
1.- Importing MATERIAL.TXT is not working well, as retraction parameters loaded are not correct (always stores 255mm and 60mm/s).
2.- Importing MATERIAL.TXT is not permanent, as when the machine powers off the new profiles disappear.
nallath 1,067
Cura doesn't know about the values in the materials.txt file. Cura has no way of being synced with it either. The UM2(+) decides on it's own what those values are, based on the used material.
