I forgot to update the number. Should be fixed now.
Doesn't seem like it is. I just tried manually checking for an update via the update checker and it says that no new version is available.
Cura v 2.3.0: "No New Version was found"
I don't recall Cura 2.x ever telling me when a new version was available. I use it every day and the only times I found there was a new version was someone mentioning it in this forum.
Done a Little packet sniff on Cura and it does get the info, but Cura says there's no new version. Isn't a cache issue since the info that gets from the check seems correct.
HTTP/1.1 200 OKDate: Fri, 11 Nov 2016 13:09:24 GMTServer: Apache/2.2.22Last-Modified: Fri, 11 Nov 2016 08:53:56 GMTETag: "827eaf-224-54102a1579f6f"Accept-Ranges: bytesContent-Length: 548Connection: closeContent-Type: application/json{ "cura": { "Windows": { "major": 2, "minor": 3, "revision": 1, "url": "https://ultimaker.com/en/products/cura-software" }, "Linux": { "major": 2, "minor": 3, "revision": 1, "url": "https://ultimaker.com/en/products/cura-software" }, "Darwin": { "major": 2, "minor": 3, "revision": 1, "url": "https://ultimaker.com/en/products/cura-software" } }}
Just checked, no prompt to upgrade here either
Same here, but downloading and installing it manually is not a big deal. I just installed 2.3.1 on my Mac, and all personal settings are still available
We're working on it. This should be fixed in version 2.4
Just to be sure: you aren't using a beta version are you? Beta versions don't update automatically...
Not using a Beta, correct
Just the current release.
nallath 1,067
