@blecheimer: So, did it fix your problem? I'm about to get a bearing! (I would take a thicker one if I could, but doesnt look very standard).
I did the same thing, the delrin is not good.
Recommended !
the new new kit from ultimaker, where you get all the plastic parts as one complete injection molded kit.. is that also delrin material or something different ? I have my delrins from the new kit sets and they seem ok... printing atleast 15hours every day at the moment..
But I like the upgrade idea..!
Ian
Ian -
With my dual extrusion kit, it looks like the formerly delrin ring is now injection molded plastic. I think I'll go straight to a bearing when I add the second extruder.
Chri -
Do you realize that your extruder clamp isn't closed properly? That may be why you were getting grinding problems before. If you squeeze the clamp all the way, and then push the lever so that the bolt is all the way at the bottom of the slot before you rotate it to horizontal, then it will work a lot better.
I did the zip-tie thing on my extruder as well It seems to really help
There's no need for a zip tie, if you use it right, and set the spring tension properly.
IRobertI 513
Thanks for the tip. I had a look at my delrin roller and it too is showing signs of wear. Not as bad as yours but obvious signs that it's deforming.
