I used this write-up as inspiration to be able to use my Ultimaker as a plotter. But modified the output from dxf2gcode slightly so I could use it with the SD card. I did not use Inkscape or pronterface, but used online to convert svg to dxf.
It works great, however I have to look at how to make dxf2gcode optimize the plotting, as you can see from the video it does not follow the logical fastest path. Could be because it is meant for milling and cutting hardware.
It seem also to use the F-rate for Z-axis for retracted head movement as well, but I may just hardcode that in the g-code settings in the future.
I wish also there was a possibility for a grid or overlay in dxf2gcode, or at least a way to easily determine the output size directly.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
Torgeir 205
Hi Robert,
What a great write up, thanks a lot..
Thanks.
Torgeir.
AreDigg 8
