Can you set concentric fill for bottom layer only?
Yep; "Top/Bottom pattern" for all top/bottom layers and "Bottom Pattern Initial Layer" for just the first layer. I nagged the guy building the engine for quite some time for the second option
1
burtoogle 516
In the speed settings, set the number of slower layers to be > 0. It will speed up over the first N layers.
yellowshark 153
Hmn, well yes it does! I have never seen different speeds on the intial layer. I.E. if print speed is 50mm/s amd initial layer is set to 20mm/s, everything on the intial layer gets printed at 20mm/s. I will cc @nallath in here as I have no idea why you are seeing this.
Yes you have a tricky print there. I would suggest
1st layer print speed no faster then 15mm/s
Reduce the nozzle to bed depth (yes I know you have probably done auto levelling) to make sure that 1st layer is really being squashed down - you can always back it out if you go to far
nallath 1,125
Initial layer height is actually to improve adhesion (as you slightly over extrude, making it stick better). Glass plates are not that flat. I seem to recall that they are +-0.1 mm, which is why we use 0.3 for the first layer.
As for what the engine does with those settings; I don't have a good view on that.
I've had decent results with increasing brim or using raft. Another thing I tend to do is to use concentric fill for bottom layer.
ianeagland 0
