RetromanIE 41
So I removed the belt tensioner and did all of the above. Still the same sound.
The axis that pulley sits on does have a few mm of play, and has done for a while. By axis I mean the bars that also can be seen/moved from the outside of the printer(well, the ends of them can be seen and pushed). Should they be locked in?
Dim3nsioneer 559
It might come from too high tension in the long belts in your case. I see you use belt tensioners on all long belts. They are not necessary as there is a strong spring inside the sliding blocks providing the tension. If you think the tension is not equally distributed on one belt, untighten one pulley of that belt, move the printhead about three times in each direction of that belt and re-tighten the pulley again. Be careful that the axis the pulley sits on does not have any play afterwards.
Edited by GuestLink to post
RetromanIE 41
Thanks, will give that a try and report back.
