Ultimaker Community of 3D Printing Experts
Changing Cura generated start code
Posted · Changing Cura generated start code
* Tick the "use regular expressions" box (so you can use "\n" for a new line)
* Search ";LAYER:"
* Replace ";whatever gcode you want goes here\n;LAYER:"
Because you only have a single line to enter the replace code, use "\n" instead of a return
  • Thanks 1
so to make sure the replace code will be ";G90; Absolute Positioning\n;G1 F9000 X220 Y215; Quick Move\n;G1 F1000 X232; Precission Poke\n;G4 P700; Hold it hold it\n;G1 F9000 X220; Quick Move:"  right ?
the original code:
pleas tell me if anything is wrong.
thank you for everything
    Posted (edited) · Changing Cura generated start code
    Almost. Don't put a ";" in front of each line. This will make the firmware ignore the line as a comment.
    Update:
    It is also smart to put a final "\n;LAYER:" at the end, so you put that text that you are finding back in.
    Edited by ahoeben
    "G90; Absolute Positioning\nG1 F9000 X220 Y215; Quick Move\nG1 F1000 X232; Precission Poke\nG4 P700; Hold it hold it\nG1 F9000 X220; Quick Move\n;LAYER:"
    this is the code i am using
    Yes, it works for me that way.
    Can you post a screenshot like I did, and a link to a saved gcode file?
    Yes I will post a photo now
    It works for me with Cura 3.4.1. All I can think of is that perhaps something was fixed after Cura 3.2.1, but I would not know what.
    • Thanks 1
    I tried it another time and it worked
    I don't know how
    Thank you very much that was very helpful
    I know this is an old topic, but I am having the most frustrating time editing my cgode.
    First of all, im using cura 3.6 and my Machine option setting isnt even listed as an option.
    I have tried multiple text editing documents but there seems to be no way to export the edited files as gcode for my printer.
    I have to remove the G1 Z15.0 F3000 ;move the platform down 15mm as it is making my first layer print in the air
    Please help, someone, there is nothing on the internet about exporting gcode with these programs, or editing raw gcode in cura.
    On 6/21/2017 at 6:56 PM, ahoeben said:
    M104 S{material_print_temperature} ;Start heating extruder
    M140 S{material_bed_temperature} ;Start heating bed
    M109 S{material_print_temperature} ;Wait for extruder to reach temp before proceeding
    M190 S{material_print_temperature} ;Wait for bed to reach temp before proceeding
    This mistake in the code here destroyed my Ender 3 and it's enclosure. Luckily I had it in a tiled room and didn't set the house on fire. This happened so quickly that even though I was home and checking it regularly it still caught fire after only 4 minutes.
    For the love of God, please fix this now before someone else uses the same code.
    5 hours ago, haydenwicks said:
    This mistake in the code here...
    I'm pretty sure the misinput in the g-code should have been caught by a safety precaution in the firmware by usual standards. Nevertheless, sorry to hear it caught fire tho, glad to hear you are safe!
    - edit: learned which mistake.
    I fixed the old comment.
    I am very sorry that happened to you.
    I am also surprised there are still printers around that you can set on fire this easily via gcode.
    Edited by ahoeben
    Just curious , normaly on Ender3 in the firmware configuration the MAXTEMP is set to 150°C and HEATER to 275°C
    #define BED_MAXTEMP 150
    As most of the times the material_print_temperature is always upper to 180/190°C  using M190 S{material_print_temperature} should have protected your printer from accidental overheating by going over the BED_MAXTEMP limit.  What was your print temperature in that case ?
    Edited by Cuq
    Not all Ender 3 have thermal runaway protection enabled... Big fault made by Creality...
      • Ultimaker Transformation Summit
        On April 20 - April 23 we will host the Ultimaker Transformation Summit. Come talk to us via Live chat and get inspired by any of our relevant presentations!
        • 6 replies
      • New here? Register your Ultimaker for free 3D printer onboarding course
