@OlivierV: Did you check what the NFC reader test in the diagnostics menu (submenu of maintenance, submenu of system) says about that spool? Does it see the tag? Does it write "UNKNOWN" below the tag id?
Thank you Dim3nsioneer, I didn't knew that this menu exist. I will test that.
gr5 2,194
This isn't tech support - this is just other UM users helping each other.
Is it really a big deal (don't get mad - I'm just wondering)? For me if it doesn't recognize the spool, the printer just asks me and I tell it "PLA". done. Easy. Right? Or am I missing something.
Anyway contact the company who sold you the filament if you want a tag. Eventually however you will probably have dozens of spare junk tags from old spools.
Dim3nsioneer 557
