Most of us don't have a distinction between home and a prepared bed.
You can do this by messing with the gcodes in the start/end gcode tab. Learn about the gcodes first here:
Or if you only want to do this to one print ever then edit the gcode after you "prepare" (slice) your stl.
But why do you want to do this? I always run the z home command, then move the print head around with my hand and use a piece of paper to check the height at all 4 corners and make sure there is *very* little space. The paper should be just barely slightly tight.
Then when you hit print, it levels and goes to your layer 0 height (typically .3mm in Cura) and starts printing at that height above your bed.
Bear in mind also that any setting of z=0 via gcodes or the ulticontroller will only last until the printer is power-cycled. The activation of the limit switches are how the printer identifies the origin of it's coordinate system. Once you power-cyle the printer, it has no idea where it is in space until you have performed a homing operation and triggered the switches.
gr5 2,004
http://reprap.org/wiki/G-code
