Edge filling
mrcdesign
Posted · Edge filling
Hello,
I have a question, i have made multiple prints but there seems to be a problem and i cannot find the setting to change it.
Below i have inserted an image so you can see what i mean.
Below i also have the 3D model, so you can see the model should be right, and smooth.
The sides (red) seems to be fine and smooth, but the top (green yellow cyan) are messy, with openings and what not, how can i get these as smooth as the red sides? (I also have these problems with other models.
Thanks in advance,
Mrcdesign
    It's the nature of 3d printers that the more vertical a side is, the better it will look. As you approach horizontal (e.g. top and bottom) the worse it will look.
    Having said that, there should be no openings. It would be helpful to see a picture of the top of your print. Usually the issue is loose belts - most commonly the "short belts" which run to the motors but could be the long belts. Loosen the 4 bolts for the x,y steppers slide down and hold them down- pushing down - while tightening again. Here is a helpful photo of what loose belts due to a print so you can instantly visually diagnose:
    http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/?p=14396
    Make sure you FULLY zoom into that picture of the 5 cubes (it should be bigger than your monitor). And read the text associated with the picture. Also scroll down to the graphic that explains one of the issues with loose belts.
    If they are too tight they tend to stretch faster and not last as long. Also I suppose the bearings will have more resistance. But I suspect your short belts are not quite tight enough.
    I have tightened the belts, but the prints still look the same.
    I'm doubting that the belts are the cause here, because when i look at the 3D model above (inside cura) you can see that te printscheme on the top is actually with gaps.
    In my opinion the top and bottom (in this case) should be filled with circles instead of random filling, but i suppose thats not possible?
    This is just a wild stab in the dark here as I am pretty much a Noob at this printing lark.
    Check that you have ticked the 'Solid infill top' box in the expert settings!
    I have that ticked in, but there are more options in the dropdown menu, i will have a look, thanks!
    Having had a quick look at the image you have posted earlier in the thread, it looks like the top of the tyre isn't lat/horizontal, could it be that if you tried slicing it at a slightly finer resolution Cura might be able to detect the slope?
    Indeed its not flat.
    What is "slicing at a slightly finer resolution"?
    Sorry im still new to printing, where can i find that setting?
    Basically it is under 'Quality'
    try slicing it at 0.1mm (layer height) if you are not already.
    It might be helpful if you post up what settings you are using.
    Ah right.
    Basic
    Layer height 0.1
    Wall thickness 1.0
    retraction on
    bottom/top thickness 2
    fill 20
    pspeed 50 mm/s
    Need to know anything else?
    Printing temp?
    have you checked the diameter of your filament?
    I wouldn't have thought you need to set the top/bottom so high. 0.8mm is usually fine.
    Bob
    I have printed in 2 temperatures
    Above is 225C
    My newer model is 215C, but its still not good.
    Diameter is 2,89
    Which was put there automatically
    Let me put 0,8 back then.
    the diameter of the filament is pretty important. the default setting will probably not be correct for the filament you are using.
    Have you got a pair of Vernier calipers to measure it with?
    Ok thanks.
    I dont have them with me here, but i have a ditigal one somewhere, ill measure it and adjust it.
    gr, Marco
    then. try and run Cura on it again and see what happens.
    Filling circles is a difficult task. Hatch filling will never be as good as concentric filling, in this case as its a circle, try using slic3r with the concentric top and bottom layer filling. The results will be much better.
    There are no gaps to span with this part so there are no stinging/retraction issues so I would print it hot and fast. 240C at 100mm/sec is conservative. If you do .1mm layers then print even faster. 150 or 200mm/sec. Don't print this fast unless temp is a minimum of 230C. 240C is better. None of this will make your print better but it will save you time.
    infill has nothing to do with top/bottom/sides. infill set to "line" is fine.
    your sides should *always* be a multiple of your nozzle. Your nozzle is .4 so your sides should not be 1mm - change it to 1.2mm (3 passes) or .8mm (2 passes).
    Make sure "joris" and "skin" features are turned off as they can mess things up.
    So far nothing I have said will fix the top/bottom.
    Cura only fills top/bottom with diagonal lines (in alternating directions). Cura will not do any other pattern. I don't know about other slicers but lohia above suggested slic3r. Don't be afraid to try other slicers. kisslicer in particular is easy to use - a gui very similar to cura. If you want to fill in the gaps in the top of the tire then the only thing left to try is to increase the amount of plastic extruded. If you have a UC you can control "flow" once the print job has started. It's in the "tune" menu. Increase to 150% when it gets near the top of the tire.
    Alternatively if you don't have a UC you can lie about the filament diameter. To increase by 50% (that's a lot!) you have to lie about the diameter which changes as the square root of the area. So sqrt(1.5) is 1.22. 3mm filament/1.22 would be 2.45 mm. That's an awful lot of extra extrusion! Maybe only 15% is enough? 3/sqrt(1.15) is 2.79mm.
    Thanks for the information, i will try Slicer to see what happens. And bookmark this page for the other info.
    I might be a little bit crazy, i have installed slicer, set it up properly, with the concentric and such. but how do i get it to print? Or does slicer only slice and i have to import in cura (which i cant find either)
    If you have an ulticontroller then just copy the gcode to the memory card. If not then google and download "pronterface printrun". it's free and works great. Never use pronterface and cura at the same time as this causes strange behavior that you will think is a bug in one or the other.
    I think you can get it here:
    http://koti.kapsi.fi/~kliment/printrun/
    So Slic3r cannot print from itself? Only prepare models?
    You could also use Repetier Host which is a front-end for Slicer, and also has a printer interface capability for sending the gcode to the printer, and also does a nice job of visualizing gcode for testing whether the gcode is doing what you expect it to.
