But anyway I'm not sure why you care? The current accel settings on UM printers is set so that it prints just fine. Tell me why you care about jerky speeds and then I can tell you more.
Hi gr5,
My machine is a UM2ext.
If you take a look at the image, you can see the degradation in print quality when the speed is increased.. and you can really notice the print head going faster and slower in jerky steps.. obviously undesirable. The effect disappears when you drop the speed back down to 100%.
It's as if the UM is dithering between fast and slow speeds, maybe to acvhieve the 'average' speed of 125%?
gr5 2,069
Which printer? UM printers (UMO, UM2, UM3) use the Marlin firmware which doesn't control jerk but does control acceleration. You can increase the acceleration (I think the default is 5000 but UMO and UM2 can do 9000 usually no problem if you oil things) too much you will get missed steps. If you decrease it you will get smoother motion but the print will take longer.
High acceleration (which gives you high jerk) gives you ringing (a problem for some people). But it also causes more even extrusion (corners don't bump out as much).
Low acceleration gives you less ringing but takes longer and you get more variation on the extrusion such that infill sometimes fails and corners are thicker (bulge out) and a little after corners is underextruded.
There are other printers where you can control jerk (it's a physics term - look it up on wikipedia) like the TinyG controller board. Actually I think that's the only company. They have a newer controller but I forget what it's called. Oh and I think newer printrbots has a tinyG or similar in it.
