After is easy: just measure the weight of the model. If you regularly compare this real weight with Cura's estimates, then you will get a good idea of its accuracy for your type of models, and for the requirements (spare amount) before starting.
If the numbers don't agree then your printer might be underextruding.
ahoeben 1,654
See the information in the sidebar below the time estimate, right next to the "Print over Network" button
Cura 3.1 will have a bit more elaborate specification:
https://github.com/Ultimaker/Cura/pull/2700
