34 minutes ago, alexbln01 said:Try simplify3d ?
Yes - I actually have S3D v4 but stopped using it a while back since it has other issues (worse slicing than cura, worse supports, poor GUI and settings management, they don't fix old bugs and don't really improve the program. Cura evolves and has nice feature - is a living product - biggest issue at the moment is the huge speed issue that might make me use S3D again). So shifted back to Cura and then to Slic3r PE, which really does well. Didn't think S3D supported UM3 but just today found out it does. It works fast and you can save the factory files, which is very nice. The downside is then you can't send to UM3 over network but have to use USB or Thumb-drive. Seems to be no good solution for a hassle free workflow with UM3
alexbln01 2
Try simplify3d ?
