tinkergnome 927
5 hours ago, MorganLaVey said:I'm pretty new to this whole 3D printing thing and have a (possibly stupid) question about the LED lights on the print cores. We have an UM3 and I'm sure the active print nozzle light used to be orange, whereas now they are both blue when printing (The 2nd nozzle is currently inactive)> What do the LED lights mean when they are different colours? I did google the problem but was unable to find an answer
Regards
I don't know, if it is documented in public somewhere. The lights have changed over time because of one or another firmware update. So don't worry.
gr5 is right, currently it's "ultimaker blue" in idle mode, (kind of) "glowing orange" during heatup and simply white during printing.
The file "/usr/share/griffin/griffin/led/controllers/headSlotController.py" is responsible for this behavior (you can double check it, if you connect via ssh to the printer).
gr5 2,194
I'm not sure but I think maybe blinking red/orange when heating or cooling. Possibly white (or light blue) when at temp? Definitely blue when it's safe to take the core out (around 40C or cooler). I don't know the full answer. Hopefully someone else does.
