15 minutes ago, gr5 said:Adding more filament should work but I'd just remove the bowden from either end. Remove the clip. Push down firmly on the collet so that it's all the way down and then at the same time pull the bowden straight up.
Thanks but do you know how to go about doing that? I disatached the tube from the feeder end. It's still attached to the extruder.
And I'm not even sure what you mean by bowden... :/
gr5 2,210
