You'll have to learn how to get parts to stick very well if you will be leaving your printer unattended:
You can get all that plastic out using a hot air gun but it's going to take you a long time. A hair dryer might work also - not sure. You need to get it up to around 60C.
fbrc8-erin 296
This generally happens if your print detaches from the bed during printing--it will attach itself to the nozzle, and start going up into the printhead because there's nowhere else for it to go. I recommend reaching out to your reseller.
Derek1984 0
Thanks for your help. I think you are correct Erin. I checked the part before leaving for the day, 1 hour into the print, and it looked great. In there morning there was no trace of the part. The build plate was completely clean.
