SOLVEDUM3-Extended firmware on regular UM3 after reseller service..
I'm going to guess you will have to put it in developer mode and ssh into the machine (in dev mode it tells you the ip address). Do you know how to use ssh @rasmus? If not I can send you instructions. username is root, password is ultimaker. But I don't know what to do after that.
Posted
· UM3-Extended firmware on regular UM3 after reseller service..
Indeed the firmware is the same, there is 1 firmware for all machines. The type of machine however, is stored on internal EEPROM on the board.
The command "python3 /ulti_installer/configure_eeprom.py 9066" (or 9511 if you need an extended instead of a normal UM3) will change the machine type. Needs a reboot before it's picked up.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
gr5 1,516
Wow! This is a great question. Maybe Erin knows. The firmware is here:
http://software.ultimaker.com/jedi/releases/
But that somehow "knows" which type of machine you have. Maybe it's a jumper or something.
@fbrc8-erin @Daid @neotko @nallath - do one of you know how to tell a UM3 that it is not an extended?
Daid 298
Rasmus 0
Amazing, my Ultimaker is now over its identity crisis! Thanks @gr5 and @Daid for quick replies and good instructions!
