The start gcode can contain replacement patterns such as {material_print_temperature} which will be automatically replaced with -in this case- the material temperature. Now there is no setting for linear advance in Cura, so no replacement pattern either (or is there?).
I recently wrote a plugin to be able to enter a Z Offset in the sidebar. I can easily adapt that to add a Linear Advance setting that you can use in your start gcode (but that has no other effect). Does that make sense? I must admit I don’t know what gcode you need for linear advance.
If you really want different start gcode, and you are not affraid of editing text-files, you can manually edit your quality profiles to include start gcode snippets.
In the Configuration folder, there’s a folder named “definition_changes”, which has a .inst.cfg file for your printer(s) containing the changes you make in Machine Settings - including start gcode. The “quality_changes” folder contains very similar files, for the quality profiles you created. You can copy and edit the gcode snippets to the quality_changes files, and that will override what is set in the machine settings.
I would NOT recommend the latter route.
gr5 1,506
Well maybe you could create a different machine for each type of filament? Then each machine could have different start codes. You could also create a plugin to do this easily and the plugin input value (the gcode) could show up as one of the many profile settings. This would probably be a plugin that other people would use. It's easiest to look at an existing plugin and just make the minor modifications to make it do your gcode insertion thing.
