Posted · unable to level bed, bed too low for the screw
Hi, I have the following error "difference between printcores...." so I think it was time to make a bed leveling...but in manual mode... I tried to turn the screws to have one mm but the bed is too low... the screws were at the end of what they are able to unscrew....I still have 2 mm and nothing to turn on screw.... any ideas? (all 3 screws)
Yves
    What printer? Usually on UM printers the first turn is the wheel in front for gross adjustment and then you use the individual screws. I am going to assume UM3(X) because you said printcores.
    Also, you can get that error if there is gunk left on the nozzle or if a bit of filament dribbles out. Also, make sure you have the cores set well.
    • 2 weeks later...
    Posted (edited) · unable to level bed, bed too low for the screw
    I have struggled with manual levelling as well. After a bit trial and error (and a lot of forum searching) I have found a sufficient method for manual levelling.
    Sice I have dropped the auto levelling completely.
    1. Start manual level mode.
    2. Before rotating the knob to set the z distance of far back position to 1mm, loosen the back screw for a significant amount (let say at least 2 to 3mm - just eyeball it)
    3. Rotate the knob and set the z distance of far back position to 1mm. DO NOT EYEBALL 1MM use some "1mm calibrating card*" and raise it until you feel a bit of resistance.
    4. For the other two positions use the same 1mm calibrating card and you should have enough space to loosen the remaining two screws until you feel a bit of resistance on your card.
    4.1 If you don't have enough distance to loosen the front screws go to STEP 2 and loosen the back screw a bit more. That should give you enough distance for STEP 4.
    When executing the second round/fine tuning of manual levelling do this:
    5. For fine levelling of far back point use provided UM calibration card. This is now important! Instead of tuning the distance with the screw but turn the knob - it will raise/lower the bed, and set the z distance with turning the knob until you feel a bit of resistance on your calibration card. Again, turn the knob instead loosening the screw. This is a software glitch on the UM3.
    6. Move to the front two positions and set your distance using UM calibration card. Tighten/loosen the screws until you feel a little bit of resistance on your calibration card.
    7. Follow the instructions and set the Z height of the bed as instructed by your UM.
    This should give you perfectly levelled heat bed. Turn off active levelling and test your settings on a small print. If you have any questions just ask :)
    *1mm calibrating card I made from stacking 3 business cards on top of each other and proofed it with a calliper. Use whatever you can find that is 1mm thick. I would recommend some sort of softer material like cardboard.
    EDIT: If your screws are loosened all the way then in STEP 2 tighten the screw before rotating the knob to set 1mm distance.
    Edited by brianskyze
    Unclear question
    The part of the leveling where you level it 1mm above - that's not really necessary - that's very rough and only needed to avoid smashing the glass later on.  Unless I have taken apart the bed I skip that step (continue continue continue).
