With a lot of walls is hard to get a 100% top fill, you can try to reduce the line width and lower the numbers of the outer wall to increase the top infill area, with the right amount of overlap it should works nice
Edited by MarcoUbtzYou might want thicker walls, yes. I would first try 100mm walls (all wall) and play with nozzle width but alternatively or in addition:
You want to set
Extra Skin Wall Count to 0
and
filter out tiny gaps should be checked
more discussion here:
Thanks for the suggestions.
@smartavionics had the right idea - set wall count to 1.
I have updated the discussion on Github.
1
kmanstudios 1,117
Hey there, try to put an large amount of walls in there to fill it up and then 99% infill.
