Hey thanks for the reply....
Found this
I believe it was off already. Under this control I tried all combinations at least from a "Layers" simulation display and no change, but that doesn't mean squat until I run it live.
Did I get your input right in that it should be "OFF: forcing retract?
Edited by Gene Silvernail
gr5 2,071
Look for a parameter - something like "enable/disable combing on first layer". You want to disable combing. This will make it retract on these moves. It still might leak a little but it should get much better.
When the machine is able to "comb" then it doesn't retract. Combing is basically moving from one wall to another without leaving the infill area - without going over any clear areas in this photo. With combing on it's very careful not to cross over any of these clear areas. But it doesn't retract either. With combing off - it won't avoid the clear areas - but it *will* retract.
