Mk8 feeder mount for umo+
Migo
Posted · Mk8 feeder mount for umo+
This feeder is quite new and the UMO is quite old so I think probably not.
These feeders don't really need to be mounted to anything other than the stepper.  You can just hang them from the ceiling or place them on a box.
But I'd just design my own mount.
    +1  Its hard to argue with George.  I think he's right again.  You could use the new extruder unmounted to print out a mounting bracket -or- don't mount it.  It's probably best mounted IMO.  What will work for your set up?
