I don't have an UMO, and I don't know its mechanics, so it is difficult to draw conclusions.
However, if this would be done on an UM2, then I would first look into possible causes for underextrusion. For example a deformed teflon coupler in the nozzle (don't know if the UMO has one?), a feeder or feeder drive-wheel slipping or dirty, bad temperature control (e.g. loose sensor), partially blocked nozzle, low-quality filament with variable diameter, filament stuck on the spool or wound too tightly near the end, and similar things that might cause irregular extrusion.
And only then I would look into bed leveling, for fine-tuning the result. But I don't think this is the main problem here.
Normally you should be able to get shiny, almost totally flat undersides, with hardly visible layer lines. Like in the best parts of your photo, but then everywhere. Or like this photo below. See the long name plate with copyright info (center-right): the text is hollowed-out inside the material and shines through the flat bottom, which is almost as glossy as a mirror. You can see the window reflecting in it. This material is tranparent PETG, but for PLA is should be equally smooth.
Edited by geert_2
corrected typo in UM2
aggertroll 12
No ideas?
