Is this the wipe tower?
There should be a checkbox in cura somewhere for "wipe tower". If you look at your part in slice view and you see this cube and then you uncheck "wipe tower" it should go away.
The purpose of the wipe tower is that sometimes the idle nozzle leaks a bit with a tiny "sausage" sticking out the bottom. If you don't wipe it then you get that sausage attached to the side of your print - and one on every layer potentially.
But the temperature control of idle nozzles is so good now in cura that this probably is not an issue and you probably don't need the tower.
Another purpose of the tower is to make sure the nozzle is fully primed which may, or may not, make a difference depending on what and how you're trying to print.
Thank you gr5 & |Robert|
Appreciate your time in replying.
Cura only started to show the 'tower' a couple of days ago. I didn't turn it on, so perhaps it occurred when I updated Cura
to the latest version.
Thank you
iysJohn
In CURA, it is found on Dual Extrusion -> Enable Prime Tower.
Thank you Brulti
Very kindly received answers for this from a couple of members regarding this.
Thank you all
DidierKlein 729
Hi and welcome
Can you please show a picture?
And what is the model?
