Stefania Dinea 101
I can tell you for sure that those balconies are too thin in that scale to print properly and one part seems to be flying - but might be just the angle (I figured out it's an overhand - nvm). I would print every building separately and us the touch build-plate support function. Looks good though - congrats on the UM3.
Edited by Stefania Dinea
SandervG 1,505
Hi @Alex L, Welcome to the Ultimaker community!
You could try to reduce the horizontal expansion for support, it will make the support protrude less from your model. By default it is set at 3mm I think.
Here is an example to show what I mean:
If you want to exclude some areas from getting support entirely, you could give the support blocker a chance. It is in our latest Ultimaker Cura Beta and it is fairly new so keep this in mind. It allows you to place blocks into your model, and the areas covered by this block don't get any support. By default the block is fairly big. If you want to make it smaller you should place 1 block on your model using the support blocker tool, select the scale tool and reduce the size. Using Move you can also move it around in all 3 dimensions. When your satisfied where it is placed, you can decide to add another block etc.
Support blocker tool, Scale tool and Move tool can all be found on the left of your viewer. Highlighted below:
Hope this helps!
By the way, you're printing an architectural model. Perhaps you find this Architecture category interesting to follow too. User @Stefania Dinea posts guides frequently, perhaps they're also useful for you, or your 2 cents could help someone else. If you want, you can follow it using the top right button.
Alex L 29
Thanks @SandervG I'll try downloading the beta version of Cura and see what this does to the print times
