mezger 0 Posted April 8 in UM2: why is my infill so bad and the borders are good? Hi, I’m trying to print using pla 1.75mm with 0.4mm nozzle. The borders are good, specially see in the picture a surface which was printed ok. However, the quality of the infill is really bad. (Set to 30%). Settings: speed: 90%, T:210C, material flow: 180% which setting do I need to tweak? Thanks Share this post Link to post Share on other sites
kmanstudios 505 Posted April 8 in UM2: why is my infill so bad and the borders are good? what slicer? If Cura, then slow down the infill speed. Share this post Link to post Share on other sites
mezger 0 Posted April 8 in UM2: why is my infill so bad and the borders are good? Yes. I’m using cura. I’ll slow it down do 70% and see if it works better. Thanks. Share this post Link to post Share on other sites
phantom 5 Posted April 8 in UM2: why is my infill so bad and the borders are good? 70% of what speed setting? Share this post Link to post Share on other sites
mezger 0 Posted April 8 in UM2: why is my infill so bad and the borders are good? I reduced from 100(!) to 60. The result was good, thanks. Share this post Link to post Share on other sites
yellowshark 123 Posted April 9 in UM2: why is my infill so bad and the borders are good? Not sure I understand why you have your flow setting at 180% instead of 100% or very close. Maybe you are compensating for something else that is wrong? Share this post Link to post Share on other sites
mezger 0 Posted April 9 in UM2: why is my infill so bad and the borders are good? Exactly, I was experimenting while printing and found that this setting was good. I now reduced the speed in cura and returned to 100% speed in the printer menu. That works better. 1 hour ago, yellowshark said: Not sure I understand why you have your flow setting at 180% instead of 100% or very close. Maybe you are compensating for something else that is wrong? Share this post Link to post Share on other sites
phantom 5 Posted April 9 in UM2: why is my infill so bad and the borders are good? 2 hours ago, mezger said: Exactly, I was experimenting while printing and found that this setting was good. I now reduced the speed in cura and returned to 100% speed in the printer menu. That works better. Speed is in mm/s not %, you need to check the cura settings, not the Ultimaker setting on the display as that is just the percentage of what you set as speed in cura. So what is the speed setting you used? Either way it's sorted but it will make communication a lot easier if you use the correct terminology Share this post Link to post Share on other sites
kmanstudios 505 Posted April 9 in UM2: why is my infill so bad and the borders are good? The 3 hours ago, phantom said: Either way it's sorted but it will make communication a lot easier if you use the correct terminology It is confusing as it is when this is what you see, or where he got the information he was citing. So, checking the cura settings is checking the displays? No? That in itself is a bit confusing and I have been using this thing for over a year now. A bit of elucidating to clear the information you put forth would be appreciated. Share this post Link to post Share on other sites
phantom 5 Posted April 10 in UM2: why is my infill so bad and the borders are good? 8 hours ago, kmanstudios said: So, checking the cura settings is checking the displays? No? That in itself is a bit confusing and I have been using this thing for over a year now. A bit of elucidating to clear the information you put forth would be appreciated. Indeed it is not an easy process and has a steep learning curve, and would have elucidated if asked what was meant but first let people think about it, as he might have found what I meant right away. You learn faster when finding it yourself then people telling you how it works. Share this post Link to post Share on other sites
kmanstudios 505 Posted April 10 in UM2: why is my infill so bad and the borders are good? 56 minutes ago, phantom said: Indeed it is not an easy process and has a steep learning curve, and would have elucidated if asked what was meant but first let people think about it, as he might have found what I meant right away. You learn faster when finding it yourself then people telling you how it works. Not sure I am fully on board with that as it is a bit steep. But, I do think you have a good reason....I guess better to let him ask. Share this post Link to post Share on other sites
