My line widths are all 0.4mm and I'm printing on the original Creality CR10 with 0.4mm nozzle, I changed the acceleration because I thought it was too much, I decreased it in hopes it would spend longer on the corners as it's under-extruding on the corners themselves too, and just after. I tried changing it back to original speed just now and it didn't make a difference.
"retract at layer change" is unticked.
I'll look into calibrating the extruder
Thanks
Edited by Marco117
gr5 2,194
What are all your line widths and what is your nozzle width - this is very important.
Also what kind of printer is it?
Also are you sure it's 300mm/s/s acceleration? That's very slow. That alone could explain the problem because it would have to slow down A LOT for the corners and sit there and over extrude then slowly build up back speed and underextrude coming out of the corners.
It's probably not this but make sure "retract at layer change" is unchecked.
I'm thinking it's probably underextruding everywhere it's just worse on this corner. I would have the machine extrude exactly 100mm and see how far the filament actually moves and maybe change the steps/mm (in other words calibrate the extruder).
