To add strength around holes or other features you can use "infill meshes" - these allow you to specify regions of your print that have modified infill so in my example below I have upped the infill density in the regions around my bolt holes. Interestingly, the infill mesh can have walls so your idea of having internal walls is actually achievable.
Hope this helps!
gr5 2,230
There a few ways to do this.
1) The way you mentioned works pretty well. Even though the pattern is "cross hatched" if you print it properly there should be no "grain". I know that higher temp materials like ABS often have a grain but this just means you need to learn to print ABS hotter. But I think you will like method 2 better:
2) Sometimes I model "needle thin walls" in my print. model an internal cuboid inside your part that is thinner than paper. Vertical walls so the slicer can't miss them. Walls that don't reach the outer walls. Imagine vertical pieces of paper - only as tall as you want your "ribbing". But hollow instead of solid. Hollow walls inside your part. Radiating out from your screw holes. You can model groups of these walls. Make the width tiny - say .01mm. You can put bundles of these radiating out from your screw holes. .01 is so small it will be filled in. So the printer will do "shell" around these "hollow walls" and create the structures you are looking for. Space the walls at least 2X the nozzle width apart. This will control the direction of "shell" lines in your ribbing so you can make them radiate outward and avoid that cross hatch pattern. This will work on any slicer - not just Cura. The height of these walls will control the height (inside your part) of these ribbing structures.
