Sorry guys, it was my bad...
It had grinded the filament and then managed to get a grip again and feed it a bit more, then the grinded part got stuck just when it enters the bowden tube, so I couldn't see it until I took the feeder apart.
When trying to unload the material it wasn't retracting and that made me take the feeder apart and then I saw what happened.
JohnInOttawa 103
Two questions:
1) when you say 'out of the box' I just want to be clear, both rolls were not exposed to air for any length of time prior to this print? (1a) If the yellow had been opened, how long ago was that?
2) Did you try swapping print cores to see if the yellow prints any better through a different core?
Looks like a real annoyance. Hopefully someone smarter than me will see an easy fix and share it shortly.
John
kmanstudios 1,120
I would assume, looking at this that your AA print core for the Yellow is dirty and may need a hot and cold pull to make sure it is working fine.
And, I am assuming you are using a UM3 series with print cores and that you are using the AA print core for the yellow material. And, that it is seated correctly.....
