kmanstudios 1,120
All of @gr5's advice is spot on. But I did some looking around and this is a new filament. Not a lot of information about it, but they apparently do have a forum.
Basically, you are treading on new ground with this stuff. I look forward to hearing your thoughts. To me, that says more than reading an ad piece. Ads cherry pick information. Users call it like it is.
Welcome to the community and please keep us in the loop! :)
gr5 2,330
The failures are underextrusion. Unfortunately there are dozens of possible causes.
I would squeeze the feeder lever, remove the filament half way and try adding a drop of oil to the filament, then inserting the filament back in. This can help a lot and won't affect the quality of the prints (really!).
Also try printing a bit slower even though 30mm/sec is on the slow end, try 20mm/sec. Or when it starts failing go into the TUNE menu and play with feedrate % (66% will convert 30mm/sec to 20mm/sec). And play with temperature.
Did you do a cold pull after you did the failing print and before the good one? If so maybe it was a partial clog. If not then probably not a clogged nozzle ?
When it fails look at the filament in the bowden and near the feeder and see if there is something obvious (maybe the filament is curling up instead of moving along the bowden or getting tangled in the feeder).
