kmanstudios 1,120
I am curious as to why you put the overhang degree setting to 15°. It usually defaults to 45°. Changing that to a low number increases the areas of support. This may not be needed.
Also, change the support horizontal expansion to something very small or even zero. This will greatly eliminate a lot of support on edges and such.
You can also go into 'per model settings' and set parts to just not have support at will. That is also where you will find the support blocker @Brulti mentioned.
1
Brulti 177
You can find all the settings for the supports in the 'Support' menu. You'll have to play with the various distances, placement, extension and such to find out what works best for the parts that you are printing.
Also, if you want to avoid support in some parts when printing multiple parts at the same time, I'd suggest using the support blocker feature. You put that over the small parts and CURA won't bother generating supports for them.
