foehnsturm 970
It should be there somewhere but I had no luck with a quick search. So:
Tinker-Mark2-dual -> Standard UM2(+) Mark2 but without the tiny Mark2 PCB
Tinker-Mark2-expansion-board -> UM2(+) Mark2 with the Mark2 PCB
--- extended --- > same for UM2(+) Extended printers
I assume you don't have the PCB as you had to extend cables.
gr5 2,224
In the past people have been all posting questions in this thread below - your answer might already be on one of those 6 pages of questions and answers. I'm not sure if @foehnsturm is more likely to see a post there or if you'll get a reply from him here. But I just mentioned his name so hopefully he'll see your question.
