6 minutes ago, fcrass said:Why not? I could easily disassemble the nozzle.
OK, maybe "absolutely should not, unless you want to break your printcore" would be the appropriate wording... see this thread:
Edited by P3D
1
P3D 46
You can't swap the nozzles on the original UM print cores. If you want to do this, you have to buy 3rd party print cores like the 3Dsolex HardCores. If you want to go for minimizing downtime, the core-swap concept is about as good as you can get, apart from the price.
fcrass 0
Thanks. I'll have a look at those.
