I know you say you want to use Cura, but the options with post processing are limited. If you really need to tweak different heights (or parts of the item) Simplify3D gives you way more flexibility.
Multiple processes would make cura awsome?
You can also use per model settings, and either cut up your model beforehand and reassemble them in Cura, or by using the Mesh Type dropdown you can use a mesh as a modifier mesh. Caveat: you cant change the layer height in this way.
On 11/9/2018 at 8:27 AM, ahoeben said:You can also use per model settings, and either cut up your model beforehand and reassemble them in Cura, or by using the Mesh Type dropdown you can use a mesh as a modifier mesh. Caveat: you cant change the layer height in this way.
yes is the only possibiliti.. simply3d have a big price.. i'm not a professional maker..
thanks all.
nallath 1,120
Have a look at the g-code postprocessing plugin. You can find it under extensions in the top menu bar. The tweak at Z might do what you need.
