possibility to create different options for the same piece
nasosan
Posted · possibility to create different options for the same piece
hi,
Is it possible to make the piece, a cylinder for example, be printed with different options depending on the height? or certain portions?
I know that with slic3r it is possible but I can not do it and I would like to continue using cura
thanks
    I know you say you want to use Cura, but the options with post processing are limited. If you really need to tweak different heights (or parts of the item) Simplify3D gives you way more flexibility.
    You can also use per model settings, and either cut up your model beforehand and reassemble  them in Cura, or by using the Mesh Type dropdown you can use a mesh as a modifier mesh. Caveat: you cant change the layer height in this way.
    yes is the only possibiliti.. simply3d have a big price.. i'm not a professional maker..
    thanks all.
